1998 Ford Escort radiator fan is not working along with tem
ASEMENJUK
  • 1998 FORD ESCORT
Engine Cooling problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic 141k miles
radiator fan is not working along with temperature gauge showing wrong temperature. Thermostat & sensor or sender (don't know right name ) on upper part of thermostat was changed. Same result - they are not working.
Monday, November 17th, 2008 AT 12:47 AM
All those good stuffs replaced and still happening-could be a wiring problem, the fan relay or the computer itself
Saturday, June 6th, 2020 AT 12:45 PM
ASEMENJUK
What is the name of the sensor located on lowest part of thermostat? And what is it for?
Item no.33 is the engine coolant temperature sensor I've looked for an engine temperature gauge sendng switch non was listed.
Saturday, June 6th, 2020 AT 12:46 PM
ASEMENJUK
We change the gauge sensor, seems like temperature gauge is working now. What is the temperature, when radiator fan is turning on? Tha car is Escort ZX2 1998.
