1994 Ford Escort charging system
JROCK1223
  • 1994 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 185,000 MILES
Ok, I have a problem with the car dieing and or the battery dieing. Got a new altenator and battery, same result. I have a broken wiper switch so I have the wiper motor unhooked. Its a work in progress. What could be killing my car?
Sunday, February 24th, 2008 AT 8:30 PM
Lets start by looking for a short somewhere in the electrical system. Disconnect the negative battery cable put a test light in between the cable and the battery negative post-Is the test light lit-if so start removing fuses one at a time -the fuse that turns off the light is the trouble circuit.
Did you checked all the fuses involved see below
https://www.2carpros.com/forum/automotive_pictures/12900_alty_11.jpg
Monday, February 25th, 2008 AT 3:15 AM
