1993 Ford Escort WILL OT START
DUKE27
  • 1993 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 95,000 MILES
IF ANYONE CAN HELP WOULD BE GREATFULL MY ESCORT WILL NOT START WAS TOLD IT WAS THE IGNITION COIL OR CRANK CENSOR HAVE CHANGED BOTH, STILL NO JOY. I DO HAVE SPARK BUT NOT VERY GOOD ONE, IF I KEEP TURNING THE ENGINE IT DOES SOMETIMES FIREUP BUT ONLY ON TWO CYLINDERS. HAVE NOW BEEN TOLD IT COULD BE IGNITION MODULE, MANUAL SAYS ITS ON LEFT HAND INNER WING BUT I CANNOT FIND IT
Thursday, September 4th, 2008 AT 1:11 PM
BMRFIXIT
  • 19,053 POSTS
Step back take a deep breath and start fresh.
Check the basic
check for fuel and fuel pressure
check for spark on all cylinders
check injector pulse
check timing belt and timing marks
check for compression
let me know what is missing
Thursday, September 4th, 2008 AT 1:16 PM
DUKE27
Thanks for that I have checked all and everything seems ok, could it possibly be the cam censor not working
Saturday, September 6th, 2008 AT 2:38 PM
BMRFIXIT
  • 19,053 POSTS
If the cam sensor no good, u will lose injector pulse or some other thing
u saying u have every thing
then I would check if u have contaminated fuel
catalytic converter and exhaust back pressure
spark good (thats to me means module and the ignition system is good )
you have fuel and good fuel pressure thats indicate fuel filter and fuel pump in good condition
compression good timing possible OK too
Saturday, September 6th, 2008 AT 7:31 PM
DUKE27
Going to check if contaminated petrol where I maybe should have started
Thursday, September 11th, 2008 AT 3:26 PM
