1993 Ford Escort Grinding Noise
128,000 MILES • 4 CYL • FWD • AUTOMATIC
RWHALEY228
  • 5 POSTS
I just replaced the rotors & pads on this car and there's a horrific grinding noise when the wheels turn. So its just been pulled forward & back again. A metal clip on the pads touches the rotor, not the braking surface but where it fits onto the hub. Any ideas, I checked the pads to make sure they were the right ones, and thats what it calls for?
Sep 4, 2010 at 10:35 AM
  • 110,246 POSTS
The metal tab is a brake sensor designed to touch the rotor when the brake pads get below 2/32". They are to warn you that the brakes are about worn out. However, if the pads are new, they shouldn't touch unless they are bent. Check them closely to see if there is evidence of them being bent. If you can, bend them back so they don't tough until there is aprox 2/32" of brake pad left.
Let me know what you find.
Sep 4, 2010 at 2:36 PM
RWHALEY228
  • 5 POSTS
Thank you Joe, I saw those tabs touching and it did'nt seem right. But I'll sure remedy that.
Thanks Again,
Richard
Sep 4, 2010 at 10:15 PM
  • 110,246 POSTS
Glad to help. Let us know if you have questions in the future.
Sep 5, 2010 at 5:17 PM
