1993 Ford Escort Not in gear
115,000 MILES • 4 CYL • 2WD • AUTOMATIC
ERINNASS
Today the car began to feel like it wasn't in gear as I was driving it. I would stomp down on the gas and the car would lurch then the problem would stop. But, as I drove further, the problem began to happen more and more often. I got home, called my husband, and he told me that all it needed was a tune up and it was still drivable. I had an appointment this evening, so I started the car up and less than a quarter of a mile down the road the car really did pop out of gear and would only rev in neutral when I pressed the gas. I turned the car off, turned it back on, and it went into gear again, so I turned around and took the car back home. What is the problem with the car and what is a ballpark figure on what a repair of this kind would cost (a breakdown on the cost of parts-new and used- and the cost of labor)? Thank you.
Jun 16, 2008 at 10:30 AM
BMRFIXIT
  • 19,053 POSTS
As a 1st step I would check the tranny fluid and make sure fluid full and clean
and then if all OK and still going in neutral on you
it may need a tranny
I would go with a rebuilt one about 1300 parts and labor \
used I thing they are about 150 - 300 $
and then labor about $350 depend on the shop and how much they charge per Hr
but check the tranny fluid 1st and adjust as needed
Have an automotive repair question!
Sign up and ask your automotive question !
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
Jun 16, 2008 at 10:53 AM
