1993 Ford Escort
GITTERBUG_22
  • 1993 FORD ESCORT
Engine Cooling problem
1993 Ford Escort
i recent purchased a new fan relay for my car but the fan is still not kicking in so wondering what could be causing it to still do that
Friday, August 13th, 2010 AT 8:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If fuses and relay is goood then suspect faulty coolant temperature switch (mounted in radiator tank).
Friday, August 13th, 2010 AT 8:21 PM
SGT. FOX
You may need to replace the thermostat, and/or the temp. Sensor that tells the fan to turn on. I suggest you buy parts like these first because they run about $15 - $25. I need more details though.
Friday, August 13th, 2010 AT 10:37 PM
