1992 Ford Escort No spark
ODDJLYONS
  • 1992 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 12,000 MILES
This is a weird one. My son called from college and told me his Escort had died. He's a good troubleshooter and discovered he has spark to only one plug. What could be causing this? Todd J.
Thursday, August 6th, 2009 AT 10:54 AM
BILLYMAC
  • 2,204 POSTS
Hi
two things come to mind. Tfi module or ignition module.
Or broken camshaft. Make sure the cam is turning and working valves on all cyls. A compression test will verify the cam works.
The module can be tested at most parts stores. Hope this helps billymac
Monday, August 17th, 2009 AT 5:06 PM
