HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Escort
Engine
Symptoms
Overheat
SPONSORED LINKS
1992 Ford Escort
TRISCH
MEMBER
1992 FORD ESCORT
Engine Cooling problem
1992 Ford Escort 4 cyl Two Wheel Drive Manual
today my car read that it was hot, but it has no thermostat, has oil and antifreeze, and the fan works fine. What could be wrong?
Tuesday, July 8th, 2008 AT 7:11 PM
KHLOW2008
MECHANIC
Hi trisch,
Why no thermostat? If the antifreeze is not flowing fast enough, the water pump could be faulty or the radiator is clogged.
If the reading is high but the engine is not hot, then it could be a sending unit or gauge problem.
SPONSORED LINKS
Wednesday, July 9th, 2008 AT 9:10 AM
Please
login
or
register
to post a reply.
Related Engine Overheat Content
1992 Ford Escort Overheating
The Car Will Shoot Coolint Out Of The Radiator Cap When I Start The Car With The Cap Off And I Know That The Head Gaskit Is Not Blow Because...
Asked by
Larry925
1 ANSWER
1992
FORD ESCORT
VIDEO
Is Your Engine Cool Enough to Check?
Instructional repair video
GUIDE
Overheating Symptoms
An overheating engine is never a good thing to have happen. If the problem is caught quickly you can save the headache of a major engine repair. Knowing the information from...
1997 Ford Escort Overheating
My 1997 Escort Overheats. We Have A New Rad, Thermostat, Flushed Entire System Several Times. Just Finished Putting In New Head Gasket...
Asked by
garyvac2
1997
FORD ESCORT
2001 Ford Escort Car Over Heating
Car Overheating And Oil Light Comes On Showing That It Is Extremly Low. I Checked Oil And It's Full. I Also Had The Oli And Filter...
Asked by
Blueescort
1 ANSWER
2001
FORD ESCORT
1993 Ford Escort Engine Overheating
I Own A 1993 Ford Escort, 1.9 Liter Single Overhead. A Few Months Ago, My Car Began To Overheat. I Can Drive It For About 3/4 Of A Mile...
Asked by
Lars Malachowski
1993
FORD ESCORT
1997 Ford Escort Car Overheating And Then Temp Goes...
Engine Cooling Problem 1997 Ford Escort 4 Cyl Two Wheel Drive Automatic A Supposed Mechanic Decided To Drain My Radiator By Pulling...
Asked by
cjbatks
1997
FORD ESCORT
VIEW MORE
SPONSORED LINKS
Coolant Leak Repair
Online car repair manuals
