1991 Ford Escort Won't idle all the time
SLMEDGE2
  • 1991 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 179,100 MILES
I'm not sure if I listed the right cylinder size for my car; it's a standard 1.9 liter engine 5speed manual transmission if that helps. The first time I drive the car in a day it runs fine and idles all the time when I take my foot off the gas. If I let the car sit for an hour or longer, it is fine and idles as above. However, if I drive the car before an hour has passed it won't idle at all; every time I take my foot off the gas, it dies immediately and has to be restarted. The only way to prevent this is to keep my foot on the gas pedal when I stop. If I then stop driving it and let it sit for an hour, it will idle the next time I drive it. I've been told that it probably needs a new idle air control valve but I priced a new one and it costs $460.00 which I don't want to pay since the car is most likely not going to run much longer. I've had it 18 years, bought it brand new and generally it has been great. I had the head gasket and radiator replaced in 2004 and haven't had any major complaints since then.
My questions are: Is it defintely the idle air control valve and if so, what part of the engine would that be listed under in a repair manual? Can I purchase a used idle air control valve at a wrecking yard instead of installing a new one? How difficult is it to do the repair and is there anything that may occur if it isn't done by a repair technician?
Thursday, July 24th, 2008 AT 11:57 AM
BMRFIXIT
  • 19,053 POSTS
How about taken it out (idle air valve ) and clean 1st
I would try it
A used may be ok or not it is a chance
the price u have on a new one very high for me
I would check some where else
Sunday, July 27th, 2008 AT 8:14 PM
