1991 Ford Escort leaking transmission fluid
1991 FORD ESCORT
PEG835
Transmission problem
1991 Ford Escort 4 cyl
Is there a gasket that can be replaced or a filter to stop the transmission from leaking? The cars value is not much so if the leaking is something major, it probably wont get fixed, however it is my only transportation right now so if there's something I can do to prolong the use of this car , anything that could possibly help, I would gratly appreciate it. thanks
May 28, 2008 at 5:02 AM
  • 31,937 POSTS
Hi there,
There is a pan gasket & a few seals that can be replaced i would get it washed down first and get a mechanic ti inspect & report exactly where the leaks are.
mark (mhpautos)
May 28, 2008 at 10:04 PM
