1988 Ford Escort Wont Start
MCMECHANIC
  • 1988 FORD ESCORT
  • 4 CYL
  • FWD
  • 65,000 MILES
"I have a 1988 Ford Escort, that wont turn over. I was told that a short occurred, causing some sort of surge frying my coil, which resulted in timing belt damages, which also cause water pump failure. I was told I needed to take out spark plugs to clean them, replace coil and water pump, and refill coolant. Does this sound legit?"
Sunday, September 28th, 2008 AT 2:29 PM
BMRFIXIT
  • 19,053 POSTS
Removing the plugs clean and or replace is not a bad idea
you have changed the water pump and timing belt
recheck timing marks
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Sunday, September 28th, 2008 AT 7:16 PM
