1984 Ford Escort 84 Escort gt
RICHIEJRO5
  • 1984 FORD ESCORT
Engine Performance problem
1984 Ford Escort Front Wheel Drive Manual
hello when the car is running it has oil and smoke coming out of the intake and air filter
Monday, October 6th, 2008 AT 5:51 PM
BMRFIXIT
  • 19,053 POSTS
Check PCV valve and replace
check PCV valve system for a good vacuum source
check oil level and make sure its not over filled
if all good suspect internal engine (rings and or seals )
www.2carpros.com/video
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Tuesday, October 7th, 2008 AT 6:00 AM
