1999 Ford Escort engine electrical
175,000 MILES • 4 CYL • FWD • MANUAL
DARINB
I have a 1999 ford escort SOHV The car hesetates like it has a spark plug problem when accelerating runs fine at an idle I have changed the spark plugs - fuel filter and air filter after. I changed the spark plugs the car ran fine for two days and then started running bad again - I dont know what else it could be - Mabee a bad ECM ? driving down the freeway the car will hesatate once in a while but then when push on the accelerator it hesetates worse like it has a fould plug. any idea please hellp
Apr 25, 2008 at 7:45 AM
BMRFIXIT
  • 19,053 POSTS
I noticed that you had changed the spark plugs and no mention of the wires
this is what I would do :
1. check for codes and specially if check engine is on or coming on
2. check spark plug wires (you can use an ohm meter or run car fill a spray bolt with water and spray the wires look for arcing )
3. also check fuel pressure and fuel flow
I don’t believe its an computer problem
let me know if you have codes
About 90% of the time, it due to a contaminated Mass air flow sensor. But sometimes, especially with high mileage cars the fuel pump can be going...
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
Apr 25, 2008 at 2:37 PM
DARINB
I did not have a check engine light come on at all - I had autozone check for codes anyway but they did not get any - I went ahead and purchased spark plug wires and so far the car runs great - I guese I should have changed them with the plugs and filters - Thanks for your help
Apr 25, 2008 at 4:56 PM
