Starting problem when hot, also irregular engine performance
FORDOWNER_X_2
My wife's 2004 Ford Escape XLS, 3.0L, automatic trans, 2wd, with remote start, has had a starting problem since it had 30k miles or a little less on it. The problem is more prominent when the ambient temperatures are 80+ degrees, however I have had the same problem at slightly lower temperatures. When making short trips, 1-5 miles, turning the vehicle off, restarting and making another short trip the darn thing will start and then die. Sometimes 2 or 3 short trips are fine, sometimes not. It used to take about 1 hour before the vehicle would run properly but the last time, after 3 hours, I finally made it to where she was, started the car, had to pressure on the accelerator to keep it running and keep the accelerator down slightly when stopping to keep it running until we got home which was about 10 miles. When we got home, it restarted fine!
The car now has 68k miles on it. When the car had 30k miles on it, I took it to the dealer to have the problem solved before warranty expired. Of course, they could not find a problem.
Recently, my wife called the dealer and they said "bring it in, we will not leave you hanging since you brought it in before the warranty expired." Well, they anylized the car and said that it needed an Idle Air Control Valve. They wanted to charge her to replace it. I will leave that part out. I just replaced the IACV and the problem has not been resolved. Another thing that I noticed is at 4000 RPMs, the engine acts like it is hitting a rev limiter. A co-worker said his father-in-law has a Taurus doing both of the same things.
We are going to keep each other aware of possible repairs and results.
Has anyone heard of or experienced these problems? If so, what was done to resolve them?
My Dad has a Windstar that was not starting when hot. He replaced the EGR valve and the sensor related/attached to it and it solved his problem. I do not want to buy every sensor under the hood until I find the one that fixes the problem, I can not afford to. Thanks for any help.
Sep 12, 2007 at 11:37 AM
BMRFIXIT
  • 19,053 POSTS
HELLO
I NOTICE YOU DIDNT SAY ANY THING ABOUT CHECK ENGINE LIGHT IF ITS ON OR NOT
ANY WAY
HOPE YOU CLEANED THE AREA AND THE AIR PASS WAY BEFORE YOU INSTALLED THE NEW IAC
EGR IS VERY POSSIBLE YOU CAN TRY ON THE DAY THAT THE TRUCK IS RUNNIG FINE TO DISCONECT THE VAC LINE FROM THE EGR AND DRIVE IT FOR A DAY OR TWO AND SEE
YOU WILL GET A CHECK ENGINE LIGHT PUT IF IT RUN OK KNOW YOU CAN CHANGE THE EGR
IF NOT THAN ITS NOT THE EGR .
BUT ABOUT THE 4000 RPM THIS IS NORMAL
IT SHOULD DO THAT THE PCM WILL LIMIT RPM
AND CUTS OFF THE INJECTOR TO PREVENT ENGINE DAMEGE
Aug 12, 2020 at 6:34 AM
FORDOWNER_X_2
Yes, I forgot to mention the check engine light. The light has never came on. I will try your suggestion on the EGR.
As far as the 4000 rpm problem, the engine used to run at this rate when passing or accelerating to merge into trafffic. Now it cuts out and the battery light flickers off ond on. I do not think this would be normal when it did not happen under say 25k miles.
Thanks again.
