2005 Ford Escape Hissing noise under the dash
2005 FORD ESCAPE
HEBUS
Brakes problem
2005 Ford Escape 6 cyl Two Wheel Drive 59,000 miles
When driving begin to hear a hissing noise under the dash, seems to be above the brake pedals. When you step on the brake, the noise disappears, then comes back a bit later, but at higher speeds I can't hear it.
Just had mechanic look at it and said they vacuum tested the booster and is holding vacuum. But the noise remains - please advise.
Thank you
Aug 21, 2010 at 12:30 PM
  • 110,240 POSTS
A hissing noise is usually a vacuum leak. Start by checking to see if there are any vacuum hoses in the area of the noise. Also, check the power brake booster for a leak.
Let me know what you find.
Aug 24, 2010 at 2:45 PM
