Code P0351
FIXITMR
  • 9,990 POSTS
Hi
you didn't mention if vehicle is running poorly?
Tuesday, September 3rd, 2019 AT 12:55 PM (Merged)
JC88
  • 8 POSTS
So it turns out the computer was fried. Spark plugs were the factory plugs, 1 went bad and fried the coil as well as computer driver for that coil. Replaced and is fixed
KEN L
  • MASTER CERTIFIED MECHANIC
  • 50,067 POSTS
I think you might have been right, when the coil blew out of the head, it could have damaged the computer. Please let us know if the new computer fixes it.
FIXITMR
  • 9,990 POSTS
Bad coil, bad harness, bad PCM. Coil or harness more likely, noted for harness problems.
FIXITMR
  • 9,990 POSTS
Also ford has issued a TSB that says "Some 2005 Escape/Mariner vehicles equipped with a 3.0L engine, may exhibit a malfunction indicator lamp (MIL) on with two or more diagnostic trouble codes (DTCs) for coil on plug (COP) primary circuit faults (P0351 through P0356). This may be due to the spark plugs causing RF interference with the PCM, resulting in damage to the PCM and COPs."
FIXITMR
  • 9,990 POSTS
Remove any spark plug and inspect for a 2-digit date code. If the date code is not present, replace all six (6) spark plugs with part number AGSF-32W-M1F4.
FOGUIE MCKINNIE
  • 51 POSTS
Yes it run poorly
FOGUIE MCKINNIE
  • 51 POSTS
I know what the p c m is but is the COPs
FIXITMR
  • 9,990 POSTS
Coil over plug.
