2005 Ford Escape
ROGALDE75
  • 2005 FORD ESCAPE
  • V8
  • 4WD
  • 48,000 MILES
I have a Ford Escape XLT 3.0 2005, the check engine light is on, I checked with a scan and the code says :
" INSUFFICIENCY CATALYST",
I changed the catalyst, but the light came on again, I changed the oxygen sensor (both) but continue the problem. It could be the cap fuel tank or not?
Please I need some help. TKs.
Sunday, January 18th, 2009 AT 1:31 PM
WHIPPLE1386
  • 13 POSTS
Hey...
Your gas cap wouldn't have anything to do with a catalyst code. If it were an EVAP code we you could consider your cap a problem. I have a few questions for you... Did you change all 4 O2 sensors or just 2? The Escapes have 2 upstream and 2 downstream sensors. This might be your problem. Also, you should call a Ford service department and see if there is a TSB or recall on the CC.
Hit me back if ya come up with anything
Monday, January 19th, 2009 AT 8:37 PM
