2004 Ford Escape Rattling noise going over bumps
2004 FORD ESCAPE
85,000 MILES • 6 CYL • FWD • AUTOMATIC
ENEMEE4
There is a noise like something is loose when I go over a bump. Also if I jerk the steering wheel quickly to either the left or right there is a clicking. All the sounds are coming from the front end. New front brakes @ 82,000.
Feb 1, 2009 at 8:56 AM
F4I_GUY
  • 3,302 POSTS
There is a TSB out on the passenger side top engine mount. The rubber insulator does tend to squeek and make noise over bumps and when weight is transferred.
You might want to check with ford if you are still covered under warranty. Or if the insulator has already been replaced.
Feb 8, 2009 at 9:19 AM
