2004 Ford Escape front struts and rear shocks
2004 FORD ESCAPE
RICHWILES76
Suspension problem
2004 Ford Escape 6 cyl Front Wheel Drive Automatic
how do you replace the front struts and rear shots on an 04 ford escape? i can do the job i just need a diagram.
May 13, 2010 at 3:32 PM
  • 110,240 POSTS
Do you have a coil spring compressor? Replacing struts can be a dangerous job without the correct tools. As far as a diagram, the best I can tell you is to get a repair manual for your car. This is an involved process, and I can't copy and paste from our online manual. And, for me to try to explaine it via the internet, allows too much room for error.
Regardless, make sure to have the alignment checked after replacing the front struts. If you run into trouble, let me know and I will try to help you.
May 13, 2010 at 3:55 PM
