Check Engine Light
BLACKOP555
  • 10,371 POSTS
Get wiring diagram of PCM and take off red cap on inside of PCM connector in harness and release the terminals for coil one and two and swap it and recheck for code. Can't drive like this unless you 1 and 2 coil connectors as well
Monday, July 6th, 2020 AT 5:48 PM (Merged)
JJ962
  • 23 POSTS
The code is actually P0351. Sorry. Could this also be an oxygen sensor or not?
ROBJUSTA
  • 2002 FORD ESCAPE
  • 6 CYL
  • 4WD
  • 175,000 MILES
Five days ago the engine light came on. We parked the car until yesterday although the car was running fine when it was parked. Yesterday when I opened the door the factory alarm began going off. (Lights flashing and horn blowing). So, I put the key in the ignition hoping that it would stop the alarm but it did not. So, I disconnected the negative battery cable to stop the alarm and waited a few minutes and then reconnected the cable but the alarm continued. I left the battery disconnected all night and then reconnected this morning and the alarm is still going off. Any advice would be appreciated.
Thank you!
SPECTRUM72
I've had that happen to me a few times. All you have to do is connect all battery terminals again, let the alarm go off. Close all doors and then put your key into the door lock, and then move it back and forth to lock and unlock the doors. Solves the problem for me every time.
Good luck.
KNOWLEDGE IS POWER
  • 1,136 POSTS
Ok. Now weve got something. Theres a service bulletin by ford that says this code can be set by damaged wire or connection at the PCM for this coil pack. Check the light green wire with the white stripe at the PCM plug for female terminal damage or insulation damage. The pc is in the middle of the firewall in the engine compartment I a little recess
DELLIOTT
  • 2002 FORD ESCAPE
My 2002 4x4 ford escape engine light is on and staying on. We ran is on the computer and the code p0401 came up. (Exhaust Gas Recirculation Flow Insuffient Detected). What does this mean and how can I fix it?
MIKEYBDMAN
  • 623 POSTS
It could be a bad EGR valve. Seems strange on such a new vehicle, but the trouble shooting for this code is to inspec the EGR valve and piping for obstructions and damaged or bad parts. If nothing is found it calls for doing a test with a scan tool to test the system. I am going to cut and paste the D/O of this code. Try not to have too much fun reading. :Wink:
Circuit Description
The PCM tests the EGR system during deceleration by momentarily commanding the EGR valve open while monitoring the Manifold Absolute Pressure (MAP) sensor signal. When the EGR valve is opened, the PCM should see a proportional increase in MAR If the expected increase in MAP is not seen, the PCM notes the amount of error that was detected and adjusts an internal fail counter towards a fail threshold level. When the fail counter exceeds the fail threshold level, the PCM will set DTC P0401. The number of test samples required to accomplish this may vary according to the amount of detected flow error.
Normally, the PCM will only allow one EGR flow test sample to be taken during an ignition cycle. To aid in verifying a repair, the PCM allows twelve test samples during the first ignition cycle following a scan tool Clear Info or a battery disconnect. Between nine and twelve samples should be sufficient for the PCM to determine adequate EGR flow and pass the EGR test if the system is operating correctly.
Conditions for Running the DTC
No Throttle Position (TP) sensor, Vehicle Speed (VSS) sensor, Misfire, IAT sensor, MAP sensor, Idle speed, EGR Pintle Position, ECT sensor, Fuel injector fault(s), Crankshaft Position (CKP) sensor, or MAF sensor DTC(s) set.
Barometric pressure (BARO) is greater than 70 kPa.
Engine coolant temperature is greater than 75°C (167°F).
Intake air temperature is greater than 80°C (176°F).
Engine speed is between 900 RPM and 1400 RPM.
IAC position is steady.
Vehicle speed is greater than 25 MPH.
The throttle is closed.
Commanded state of the A/C relay is steady.
Conditions for Setting the DTC
MAP changes monitored during the EGR flow test indicate insufficient EGR flow.
Action Taken When the DTC Sets
The PCM will illuminate the Malfunction Indicator Lamp (MIL) during the first trip in which the diagnostic test has been run and failed.
The PCM will store conditions which were present when the DTC set as Freeze Frame and Fail Records data.
Conditions for Clearing the MIL/DTC
The PCM will turn the MIL OFF during the third consecutive trip in which the diagnostic has been run and passed.
The history DTC will clear after 40 consecutive warm-up cycles have occurred without a malfunction.
The DTC can be cleared by using the scan tool Clear Info function or by disconnecting the PCM battery feed.
Diagnostic Aids
Important: If the EGR valve shows signs of excessive heat, check the exhaust system for blockage (possibly a plugged catalytic converter) using the Restricted Exhaust System Check. See: Diagnosis By Symptom Restricted Exhaust System Check
To verify a repair, clear info with the scan tool and run the EGR flow test keeping the following items in mind:
The PCM will only run the EGR flow test during a gradual deceleration.
The PCM will only run the EGR test during a closed throttle condition.
The PCM will only run the EGR test at vehicle speeds above 25 MPH.
Several deceleration cycles will be necessary to run a sufficient number of EGR flow test samples (9-12).
The EGR Test Counter displayed on the scan tool can be useful in determining that the EGR flow test is running and to keep track of the number of test samples taken. The counter will increment each time a test sample is taken.
Check for the following conditions:
Vacuum restriction to the MAP sensor. A restriction to the MAP sensor can cause the EGR flow test to fail due to insufficient MAP changes being monitored during the test. Check for objects blocking the vacuum to the MAP sensor. Also check for kinked or pinched MAP sensor vacuum hoses (if equipped.)
Poor connection or damaged harness. Inspect the wiring harness for damage.
If the harness appears to be OK, observe the Actual EGR Position display on the scan tool while moving connectors and wiring harnesses related to the EGR valve. A change in the display will indicate the location of the malfunction.
Reviewing the Fail Records vehicle mileage since the diagnostic test last failed may help determine how often the condition that caused the DTC to be set occurs. This may assist in diagnosing the condition.
ZELTNER
  • 2002 FORD ESCAPE
Engine Performance problem
2002 Ford Escape 6 cyl Four Wheel Drive Automatic
I have a 2002 ford escape. Lately it has been running rough and chugging. When I sit at a light, it sputters and idles rough. I have ran 1 bottle of fuel cleaner and it seemed to do ok, then we had a lot of damp weather and it started to act up again. So a second bottle went it. So far no change. Any idea?
WESALAUZEN
  • 5 POSTS
We have the same thing going on with our escape right now. It is most likely a misfire typically caused by a defective coil pack on one of your spark plugs.
They are about $65 a piece and easy to replace on the front three cylinders 3, 4, 5, but the back three 1, 2 and 3 are not so easy. You have to pull the upper intake manifold to remove and replace them.
I have been told that most auto parts stores will check your codes for you with a scan tool and that if your car has generated a code (check engine light ilumiated) you can find out which cylinder is misfiring and replace that pack. I plan to do this tonight. Anyway, I hope that helps.
SCOTTBALL
  • 2002 FORD ESCAPE
  • 150,000 MILES
Over the last 4 months I have been replacing the ignition coils at one per month. I should have replaced them all at once and saved time. The symptom each time would be a hiccup in the engine at idle that would progressively get worse to where the engine ran rough. The engine light eventually came on so I knew what to replace and the problem stopped until the next month when the next coil went bad.A similar symptom of the engine hiccup started again last week. I decided to replace the last two ignition coils to be done with the problem, but the hiccup is still there. I checked to ensure that I had hooked everything up correctly.
The hiccup is only noticeable when engine is cold at this point. It is very infrequent and random. The engine light has not come on so there are no codes.
HMAC300
  • 48,601 POSTS
Check fue pressure and see who much voltage is going to coils. It may be to high and burnging them up.
CJ MEDEVAC
  • 11,005 POSTS
WHAT ARE THE ****EXACT**** CODE NUMBERS COMING UP WHEN THE ENGINE LIGHT IS ON???.........NOT SOMEONE'S INTERPRETATION
A WHILE BACK HAD THE "BAD COIL" WITH WIFE'S '03 W/ 3.0L..........IT WOULD GIVE REAL FAST SLIGHTLY JERKY HESITATIONS FOR ABOUT 2 SECONDS, WHILE CLIMBING ANY INCLINE, THEN IT WOULD STOP
I NEVER GOT A CODE OR NOTHIN'---AFTER SOME PARTS CHANGING AND ELIMINATIONS I GOT IT STRAIGHT
A BETTER DESCRIPTION OF "HICCUP" MIGHT HELP
DEPENDING ON THE CODE(S) IT COULD BE ANOTHER PROBLEM
CONTINUE WITH THE TESTING THAT hmac300 PRESCRIBED
AT MINIMUM, TELL US WHAT YOUR ALTERNATOR IS PUTTING OUT
http://www.youtube.com/watch?v=Bzz7P3qNHcE
KEEP US INFORMED
THE MEDIC
