I would look for a wire problem. I would look at the brake shift interlock or interlock relay. This is what locks it in park until you step on the brake to release it out of park. This vehicle has an emergency override function. What you do is turn the ignition to the 1st position from off toward the on position and then step on the brake pedal and pull it out of gear first to neutral then start it.
This fuse could be blowing because of the ignition relay or shift interlock relay or brake pedal switch or the actuator itself.
If you want we do some tests that are extensive or you can take it to a shop you trust and have them check it. Let me know what you want to do and we will take it from there.
Sunday, December 28th, 2008 AT 10:12 PM
