2002 Ford Escape
MELISSA19688995
  • 2002 FORD ESCAPE
  • 6 CYL
  • 89,000 MILES
Sometimes when my suv is in park and running I hear a little knocking and also when I come to stop at a traffic light or stop sign. Should I be concern about this?
Thursday, January 15th, 2009 AT 5:59 PM
DAVE H
  • 13,383 POSTS
CAMSHAFT TICK NOISE - 3.0L 4V ENGINE ONLY
TECHNICAL SERVICE BULLETIN
Reference Number(s): 06-3-5, Date of Issue: February 20, 2006
FORD:2001-2005 Taurus; 2001-2006 Escape
MERCURY:2001-2005 Sable; 2005-2006 Mariner
Superceded Bulletin(s): 04-20-8, Date of Issue: October 18, 2004
Related Ref Number(s): 04-20-8, 06-3-5
ARTICLE BEGINNING
ISSUE
NOTE:This article supersedes TSB 04-20-8 to update the vehicle model years and Service Procedure.
Some 2001-2005 Taurus/Sable, 2001-2006 Escape and 2005-2006 Mariner vehicles built prior to 1-17-2006 equipped with the 3.0L 4V Duratec engine may exhibit a ticking noise from the left bank cylinder head, with the engine at normal operating temperature only.
ACTION
To diagnose, with the engine running and warm (normal operation temperature), using a mechanic's stethoscope determine if the ticking noise is coming from the left hand intake camshaft at cylinder number 6, (Fig. 1 ). If the ticking noise can be verified, refer to the following Service Procedure.
Fig. 1: Locations To Listen For Ticking Noise
SERVICE PROCEDURE
Remove the left bank valve cover. Refer to Workshop Manual, Section 303-01B.
Rotate the engine clock wise until the cylinder number 6 intake cam lobes are pointing up and the valves are fully closed.
Remove all left hand intake cam caps individually and reinstall them finger tight.
NOTE:THE CAMSHAFT CAPS MUST BE COMPLETELY LIFTED OFF AND THEN SET BACK INTO POSITION. LOOSENING AND RE-TORQUING CAP BOLTS IS NOT SUFFICIENT.
Torque bolts in sequence shown in Fig. 2 to 72 lb-in (8 N.M) excluding cam cap number 8L camshaft cap.
Fig. 2: Cam Cap Bolt Torque Sequence
Using a screw driver positioned on each side of the top of cam cap number 8L (Fig. 3 ) apply hand pressure and shift cam cap number 8L toward the exhaust side of the cylinder head.
Fig. 3: Torquing Cam Cap Number 8L
While holding cam cap number 8L in the shifted position, torque the fasteners number 9 (inboard) first, to 72 lb-in (8 N.M) then torque fastener number 10 (Fig. 3 ).
Install the left hand camshaft cover. Refer to appropriate Workshop Manual, Section 303-01.
Fully warm the engine to normal operating temperature to verify the repair.
WARRANTY INFORMATION
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage.
OperationDescriptionTime
060305A2001-2003 Taurus/Sable: Remove And Install The Camshaft Caps Includes Time To Remove And Install Valve Cover (Do Not Use With 6007A10, 6250AL, 6584AL)0.9 Hr.
060305A2004-2005 Taurus/Sable: Remove And Install The Camshaft Caps Includes Time To Remove And Install Valve Cover (Do Not Use With 6007A10, 6250AL, 6584AL)1.0 Hr.
060305A2001-2006 Escape and 2005-2006 Mariner: Remove And Install The Camshaft Caps Includes Time To Remove And Install Valve Cover (Do Not Use With 6007A10, 6250AL, 6584AL)1.2 Hrs.
DEALER CODING
Basic Part No. Condition Code
6A26707
Thursday, January 15th, 2009 AT 7:48 PM
