2002 ford escape 2wd. Cleaned engine compartment started up car after washing engine compartment started fine moved the car back 20ft, then disconectted the battery cables to clean. When we hooked the battery back up the vehicle will not move.
Checked the shift cable, it is moving when you move the shift lever into gear.
SPONSORED LINKS
Tuesday, June 30th, 2009 AT 10:31 AM
