Battery draining down
225,000 MILES • 3.0L • V6 • AUTOMATIC
JANET PHILYAW
I have replaced both alternator and battery in my car. Both new have been tested and are good. Voltage good on battery. When running something is still draining and making car runs sluggish. Please help!
Dec 14, 2016 at 8:42 PM
HMAC300
  • 48,601 POSTS
do a parasitic draw test on battery also check belt with a gauge normal recommended replacement of belt and tensioner is 60,000 miles.
Here is a great guide on battery draw down
https://www.2carpros.com/articles/car-battery-dead-overnight
Please let us know happens so it will help others.
Dec 14, 2016 at 10:18 PM
JANET PHILYAW
Thanks.
Dec 15, 2016 at 12:27 AM
STEVE W.
  • 15,411 POSTS
When you say sluggish, what do you mean? The vehicle does not accelerate? Seems to be held back by something? Does the engine seem to rev up easily? Does it only act sluggish while moving?
Dec 15, 2016 at 2:30 AM
JANET PHILYAW
Rpm's go down until car goes off. After further investigation I have found two wires melted together that are being replaced. I am hoping this fixes the problem.
Dec 15, 2016 at 2:36 AM
STEVE W.
  • 15,411 POSTS
The melted wires could easily be the issue. Post the wire colors either way as information like that could help others as well. Thanks.
Dec 15, 2016 at 6:22 AM
SATURNTECH9
  • 30,869 POSTS
Could have been a fuseable link that would explain the lack of charging the battery if that's what's happening.
Dec 15, 2016 at 11:14 AM
