The v sic also had seberal PCM updates for rough idles and misfires, along with poor shift quality, see if any apply to yours.
Tuesday, April 10th, 2012 AT 3:46 PM
JR2001
MEMBER
So which cat did you replace?
Monday, June 30th, 2014 AT 1:53 PM
JR2001
MEMBER
So is that the rear cat one?
Monday, June 30th, 2014 AT 1:57 PM
CHUCK26885
MEMBER
1 POST
Did you go to school for being a mechanic? If so how can a burnt valve or head gasket not show up when doing a dry virus wet test? Alos if you check these pressures 160-175 or 180 they would be in normal range telling you the problem is not internal.
