1994 Ford Majestic conversion van transmission issue
LUV VAN
I have a 1994 e-150 ford conversion van with 125 000 miles
6 cylinder engine,E series transmission
I am trying to diagnose what seems to be a transmission problem.
80 % of the time the van runs fine but occasionally at about 45 to 60 miles per hour the tranny will kick/slam back and forth between gears and makes a winding noise then after about 30 seconds it is fine.
I am mondering if it might be a computer problem ?
Could you plug it into the computer at a ford dealership to find out?
Its a great van but my wife is afraid to go on a trip until I figure this out.
Your help is appreciated.
Thanks
Oct 19, 2007 at 8:28 AM
BLACKOP555
  • 10,386 POSTS
wish i could remember hte name of it but there is some kind of switch that if the tranny does that is a common sign of it failing
Oct 19, 2007 at 8:58 AM
LUV VAN
[quote:459af1b86f="blackop555"]wish i could remember hte name of it but there is some kind of switch that if the tranny does that is a common sign of it failing[/quote:459af1b86f]
Is this switch a minor or major repair ?
Or is the entire tranny failing in need or rebuild or replacement ?
Thanks
Oct 19, 2007 at 9:25 AM
BLACKOP555
  • 10,386 POSTS
no its not expensive nor takes long to do i jus cant remember what it is. i have to look it up and check back with you
Oct 19, 2007 at 1:30 PM
