I can't figure out why my gas is leaking into the oil and there is a lot of white smoke coming out of the tail pipe. Can someone help?
Mar 19, 2006 at 5:10 AM
Perform a compression test to check for a blown head gasket or cracked cylinder head, the most likely causes of fuel entering the oil and white tailpipe smoke on this fuel-injected engine.
The owner of a 1994 Ford E-Series van with a 5.8L engine reports gasoline mixing into the oil and heavy white smoke from the tailpipe. The van had sat for months, and earlier black smoke was already fixed. The expert says a blown head gasket is most likely, a cracked head is also possible, and recommends a compression test.
