1992 Ford E-Series Van
MIMILLER
  • 6 POSTS
Engine Performance problem
1992 Ford E-Series Van V8 Two Wheel Drive Automatic
460 When weather is warm engine hesitates, loses power and stalls. Starts only after 1/2 hour or more cool off. Runs fine when cool.
Mar 21, 2010 at 12:31 PM
  • 75,988 POSTS
Next time it stalls immediately do below to find out what's missing: Fuel or Spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 21, 2010 at 5:16 PM
MIMILLER
  • 6 POSTS
Thankyou for the reply. I have also had a lot of pinging under even a moderate load, might be related? Low fuel pressure? Removed and checked the ignition module, could not get it to fail even when warm and trying over 10 times.
Mar 25, 2010 at 8:28 AM
  • 75,988 POSTS
Test the EGR valve and also the knock sensor a problem with this 2 will cause the engine to detonate/ping to inlcude engine overheating
Mar 25, 2010 at 9:01 AM
MIMILLER
  • 6 POSTS
Thanks again for the help, I am still wandering around in the dark. Coolant never over heats, guage is below half. I don't think this vehicle has a knock sensor. Think the EGR valve is still suspect? How do I check it?
How about timing chain? Maybe O2 sensor?
Mar 25, 2010 at 9:10 AM
  • 75,988 POSTS
Step 1 Do a fuel pressure check if its within specs if okay do S2
Step 2 Get a vacuum pump to check the EGR valve or use its on intake manifold vacuum to open the EGR pintle-it shpuld drop 150rpm if its functioning
Mar 25, 2010 at 9:30 AM
MIMILLER
  • 6 POSTS
Is it possible the fuel pressure might only drop when it is hot? What does printle-it mean?
Mar 25, 2010 at 9:39 AM
MIMILLER
  • 6 POSTS
Also I notice the heater flaps seem to change when under a moderate load, a load less than I would expect them to change.
Mar 25, 2010 at 9:44 AM
MIMILLER
  • 6 POSTS
I keep looking and listening for vacum leaks but have not found any??
Mar 25, 2010 at 9:46 AM
