1990 Ford E-Series Van heater core
SCTT DAVIS
  • 1990 FORD E-SERIES VAN
  • V8
  • 85,000 MILES
How do u remove heater core in my 1990 ford econoline 250
Tuesday, January 19th, 2010 AT 9:55 PM
For what liter engine?
Wednesday, January 20th, 2010 AT 3:40 AM
THIS IS MIKE
  • 686 POSTS
5.8liter
Thursday, January 21st, 2010 AT 1:17 PM
351 CID
HEATER CORE AND SEAL ASSEMBLY
https://www.2carpros.com/forum/automotive_pictures/12900_hc_2.jpg
Removal:
1.Remove inlet and outlet hoses from heater core in engine compartment. Plug hoses with a (5/8-inch) diameter plug.
2.Remove two screws retaining modesty panel to underside of instrument panel. Remove panel.
3.Remove the four screws from heater core cover located on the Left Hand side of case underneath instrument panel. Remove cover.
4.Remove screw and retaining bracket at bottom of heater core.
5.Remove heater core and seal from case.
Installation:
1.Position heater core and seal assembly and install core retaining brackets and screws.
2.Remove plugs from hoses.
3.Install inlet and outlet hoses to heater core.
4.Position heater cover and install four retaining screws.
5.Attach modesty panel to instrument panel with two retaining screws.
Thursday, January 21st, 2010 AT 3:32 PM
