1995 Ford E-Series Van heater core replacement
121,000 MILES • 6 CYL • 2WD • AUTOMATIC
KFD34
need to replace heater core
Feb 8, 2010 at 1:24 AM
RACEFAN966
  • 5,029 POSTS
Ok first remove heater hoses from core under hood and plug them. Remove the lower trim panel under glove box area. Now remove the 6 screws from heater core cover. Remove the cover and then remove the screw and bracket from core and remove the core. Replace in reverse direction. Hope this helps.
Feb 8, 2010 at 10:58 AM
