1989 Ford E-Series Van Distributor
136,000 MILES • 6 CYL • 2WD • AUTOMATIC
TWHOLLOW
Yes my van quit so I pulled the distributor cap. I turn engine and rotor does not turn. I Pull shaft and all out and feel that the gear located in the crank case is broken. So can I drop the oil pan to repair this.
Jul 26, 2008 at 10:39 AM
  • 75,988 POSTS
What CID engine is this -200/250/300?
Jul 26, 2008 at 11:01 AM
TWHOLLOW
What will this cost me at a shop to have repaired?
Jul 26, 2008 at 2:02 PM
MERLIN2021
  • 17,250 POSTS
First, have you tried to hold the rotor and spin the gear on the distributor> It could be the roll pin or key broke! You could fix that yourself either by replaceing the busted pin, or the whole distributor.
Jul 26, 2008 at 11:41 PM
TWHOLLOW
The gear inside motor casing I can feel a piece of the gear missing.
what will it cost me to have this repaired
Jul 27, 2008 at 12:45 AM
MERLIN2021
  • 17,250 POSTS
Depends if the cam needs to be taken out or not, may be able to reach thru the front...maybe up to 600.00 or so...
Jul 27, 2008 at 1:25 AM
