Replace distributor on 1994 E350 Windsor 351 engine
GOODING
Do you have any tips on this replacement before I attempt it? Is it particularly difficult or is there anything to be aware of that may help me make this a smooth job? Thank you for your help.
Oct 19, 2007 at 12:37 PM
  • 75,988 POSTS
[quote:8a059a5928="gooding"]Do you have any tips on this replacement before I attempt it? Is it particularly difficult or is there anything to be aware of that may help me make this a smooth job? Thank you for your help.[/quote:8a059a5928]
Okay 1st open up the distributor cap look at the rotor where its pointing at the distributor housing, mark it with perm. marker or white out.
At the distributor base make a mark there and the intake manifold.
When you put on the new distributor it has to be in the same position at the housing and the base marking.
Oct 19, 2007 at 1:02 PM
