Fuel pump relay location
SEMPERFI4JESUS
  • 1989 FORD E-SERIES VAN
  • V8
  • 100,000 MILES
Where is the fuel pump relay switch located?
Thursday, July 2nd, 2009 AT 3:35 PM
RAVENSANCTUARY
  • 35 POSTS
"The fuel pump relay is located on the right hand fender apron, near the battery."
This guide will help you test it.
take off the dog house and there you will see a set of relays on the left side right there next to the motor there should be about 3/4 of them as to which it is that i can,t tell you but under the hood by the batt. there is a red female plug assy that you can jump to see if the pump is actually working or not. MOST times the relay is not the fault the pumps are as there are 2 of them one in the tank one on the rail by the drivers door
Thursday, August 13th, 2009 AT 3:51 PM
MICHAEL KEATE
How do you jump the red female connector? Do you take a small lead and hook it to the positive terminal of the battery? I tried this on one of the pens and I could hear something click down under the dog house. Please advise.
Thursday, November 21st, 2019 AT 5:58 PM
STEVE W.
  • 13,628 POSTS
MICHAEL KEATE Could you please use this link and ask this as a new question? Please include as much information as possible. Thank you.
Thursday, November 21st, 2019 AT 6:31 PM
