1982 Ford E-Series Van y pipe repair
BLOVE1344
1982 Ford E-Series Van V8 Two Wheel Drive Automatic 103K miles
How do I repair a 'y' pipe with pin holes?
Thanks
Apr 7, 2010 at 8:43 AM
  • 110,248 POSTS
It if has pin holes in it from rust, the only thing you can do is replace it. If you try to weld the holes shut, the welder will most likely just blow through the pipe because it has become so thin.
May 3, 2010 at 6:47 AM
