updatesd 1/21/10
Bob, Ken, and all,
Thank you for the response, and thank you guys for what you do. I have solved the question; I did check the fuel cutoff in the trunk, it was fine I checked the valve up on the chrome rail for the injectors, and some fuel spurted out, and I could hear the fuel pump, so I figured it's getting fuel. I pulled a wire and put a spark plug on it, used jumper cables to ground it, but no spark. I checked the wire to the crank position sensor, and found it loose. Pushed it back on tight and it started right up.
Thanks again for your help; hope this might help someone else. Actually, my brother said that someone said the crank sensor wire can come loose.
SPONSORED LINKS
Saturday, January 9th, 2010 AT 3:57 PM
