My car suddenly developed "flat" spots in the steering where it alternately becomes easy and hard as you turn. There are no leaks and the fluid is at the proper level. My local repair shop flushed and changed the steering fluid and it has gotten only slightly better, but not fixed. They would like to replace the steering box and the pump for well over $1000. It seems like there might be a simpler, less costly solution other than replacing most of the big-ticket steering components> I have seen other similar problems noted elsewhere on the internet. Any help would be appreciated.
Jun 26, 2008 at 7:39 AM
