1996 Ford Crown Victoria
THAWAHSFINEST
  • 1996 FORD CROWN VICTORIA
1996 Ford Crown Victoria Automatic
wen I go to start my car it comes on but it doesnt do anything.I have to move my key rapidly up an down while moving the gear shifter on the steering column up an down. Basically I have to find drive an it want go in park. But drive an reverse works fine.
Wednesday, February 4th, 2009 AT 5:29 PM
KENBAKKA
It sound like your problem is in the shift linkage. Most likely it is caused by a worn or missing bushing. With the car not running try grabbing the linkage from under the hood (where the steering colum passes through the firewall) and wiggle it. The linkage should not move more than 1 or 2mm, if it does follow it either up or down to where it is loose and replace the bushing. The other possibility is a worn Neutral safety switch (located on the transmission) it should have a 3 wire plug towards the rear of the trans. This switch can be bypassed for testing purposes with a jumper wire (I STRONGLY advise not to leave it bypassed as it is a safety feature and will allow the car to be started while in gear), you will need to figure out which wire is 12v and which one goes to the ignition and connect the jumper between them. If the car then starts your switch could be your problem and in need of replacement.
Thursday, February 5th, 2009 AT 9:57 AM
