1997 Ford Crown Victoria
CROWNVIC6767
  • 1997 FORD CROWN VICTORIA
I have a 1997 crown victoria that shudders or acts like it is not getting enough gas when the gas pedal is pressed when the car is at a full stop at a stop sign or red light. The dealer said that the transmission needs to be flushed and the fuel filter has not been changed in a while.
Saturday, May 22nd, 2010 AT 12:37 AM
If the transmission is not slipping-do below:
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Saturday, May 22nd, 2010 AT 1:33 AM
