HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Crown Victoria
Engine
Cylinder Head
Gasket
Blown
1996 Ford Crown Victoria
ABIGAIL414
MEMBER
1996 FORD CROWN VICTORIA
V8
2WD
AUTOMATIC
187,000 MILES
Have an oil leak I was told that I have a leaking head gasket is it possible for the head to be blown or about to be.
Friday, January 25th, 2008 AT 5:42 PM
BLACKOP555
MECHANIC
Yes it is possible for a head gasket to blow, a head to crack, or a head to warp.
Friday, January 25th, 2008 AT 7:34 PM
Please
login
or
register
to post a reply.
Related Cylinder Head Gasket Blown Content
Recently Purchased This Crown Victoria From Craigslist...
Recently Purchased This Crown Victoria From Craigslist. A Few Weeks After, It Begun To Shake A Lot After About 5-minutes Of Driving. I...
Asked by
Rochester's Finest (RPD Fan)
1 ANSWER
1 IMAGE
1999
FORD CROWN VICTORIA
GUIDE
Cylinder Head Gasket Blown Test
Diagnosing a blown head gasket in an automotive engine requires a systematic approach to ensure accurate results. This guide will walk you through the necessary steps to...
2000 Ford Crown Victoria Cooling System
Drove The Car On A Cool Morning A Short Distance From My House (3-4 Miles). Stopped At Service Station Put It In Park Noticed A Small...
Asked by
strunk613
2000
FORD CROWN VICTORIA
Will Not Spark
Replaced The Head Gaskets, Spark Plugs Are Fine. Now It Will Not Spark. Temperature Reads -40. Please Help.
Asked by
Amelia Sunshine Jones
1 ANSWER
2000
FORD CROWN VICTORIA
Coolant Disappearing
Coolant Leakage, But No External Sign Of It. Is That A Head Gasket Problem Or Something Else To Look For?
Asked by
abart
1997
FORD CROWN VICTORIA
As I Was Puttin On The Hhead Bolt With The Tork Ranchh...
As I Was Puttin On The Hhead Bolt With The Tork Ranchh The Tip Of The Bolt Broke Will The Car Still Will Be Able To Drive With A Bolt...
Asked by
Anonymous
1 ANSWER
1996
FORD CROWN VICTORIA
VIEW MORE
Coolant Mixing With Engine Oil
Check Engine Light Safe to Drive?
Oil Change & Filter Replacement Toyota Tacoma
