1996 Ford Contour Signal Stops With Brakes
SAPARKS2001
hello I have a 1996 Ford Contour, and it has 87,000 miles on it. The problem that I am having is that each time I put on my left signal to turn and I step on my brakes the signal will stop blinking but when I get off the brakes it will start blinking again. Could that be an electrial problem.
May 4, 2007 at 12:52 AM
MERLIN2021
  • 17,250 POSTS
Have someone step on the brakes while you check the brake light. I bett youll find a burned out bulb...
May 4, 2007 at 7:31 AM
SAPARKS2001
[quote:178b2d2908="merlin2021"]Have someone step on the brakes while you check the brake light. I bett youll find a burned out bulb...[/quote:178b2d2908]
I have tried that and I also changed the bulbs but it is doing the same thing.
May 4, 2007 at 8:07 AM
MERLIN2021
  • 17,250 POSTS
Before you changed the bulbs were any out? If not unser the dash changed the Flasher for the blinkers, not the one for the 4 ways!
May 4, 2007 at 8:45 AM
Suggested Repair
If the brake bulbs were not burned out before replacement, replace the turn-signal flasher under the dash, not the hazard flasher.
Conversation Summary
The owner of a 1996 Ford Contour reported that the left turn signal stops blinking when the brakes are applied and resumes when the brakes are released. The expert first suggested checking for a burned-out brake bulb. After the owner said the bulbs were changed and the problem continued, the expert advised replacing the turn-signal flasher under the dash rather than the hazard flasher if no bulbs had been out.
