1998 Ford Contour Humming When Turning
RICKMAN2012
i have a 98 contour with 110,000 miles on it and every time i turn the wheel to the left(started about a month a go and getting louder) i hear a slight humming noise and when i turn to the left even more it gets louder and the noise it comming from the right front tire area. last year i had the left front inner tie rod replaced and it didnt make that kinda sound. any ideas of what it might be
Nov 10, 2007 at 8:23 AM
MERLIN2021
  • 17,250 POSTS
If you are going 35mph or faster, it could be the wheel bearing...
Nov 10, 2007 at 8:31 AM
RICKMAN2012
i think it does it around 25mph or a little faster. Is it easy to do your self or just have it taken in?[quote:1e4ea02cd1="merlin2021"]If you are going 35mph or faster, it could be the wheel bearing...[/quote:1e4ea02cd1]
Nov 10, 2007 at 8:41 AM
MERLIN2021
  • 17,250 POSTS
Depends how handy you are, the knucle must come out then there are 3 bolts on the inside then tapping it out without damaging the aluminum casting! Tricky but not real hard! If you do it the last step...torqueing down the axle nut is critical, 200 ft lbs! or you wasted your money and time!
Nov 10, 2007 at 8:52 AM
Suggested Repair
Inspect and likely replace the right front wheel bearing. DIY is possible but tricky: the knuckle must come out, three inner bolts removed, and the bearing tapped out without damaging the aluminum casting. Torque the axle nut to 200 ft-lbs or the repair can fail.
Conversation Summary
A 1998 Ford Contour with 110,000 miles hums from the right front tire area when turning left, louder with more steering and at about 25 mph or faster, and the noise has worsened over a month. A left front inner tie rod replaced the year before did not make this sound. The expert attributes it to a wheel bearing and outlines a careful DIY replacement with critical axle-nut torque.
