Check engine lights can have many different sources. Some problems are hidden and can not be found out until one problem is fixed.
You need to find a place that you can trust. If you trust this one as much as any other one, then yes, take it back. There are many advantages to keeping your business at one place. There are a larger separation from shops that stay current with technology than ones that don't. IF they are staying up with it, then that should be a factor.
When you have a 10 year old car, expect to have to put a thousand or two a year into it.
SPONSORED LINKS
Wednesday, June 13th, 2007 AT 8:51 AM
