Just pulled the codes from my 99 contour 4 cyl 2.0 143,000 miles on it. the codes are as followed P0171 and P0102 what are these codes telling me, is it the mass air flow sensor??. I just replaced the fuel filter, all 4 injectors, O2 sensor and all the plugs which look fine in color. Compression is fine in all Cylinders, but it idles rough,I'm at the point where I guess I need help with this, all help with this problem will be greatly appreciated.
Thanks, njl4
Thanks, njl4
Nov 26, 2007 at 9:26 AM
