99 contour stalls when it warms up
TOMFITZY
  • 7 POSTS
99 contour, 4 cyl, 2.0 liter. The car stsrts right up. after it warms up, I tap the pedal and let go, it stalls. If I drive it, it will stall every time I stop. The code is PO340 camshaft position sensor. I replaced it, no help. I checked the wiring from the computer to it, all good. Could it be a faulty computer, could the timing belt jump?, It happened all of a sudden. Could the crankshaft position sensor set off the po340 code? Please help. Tom
Aug 19, 2007 at 1:49 PM
  • 75,988 POSTS
Here's the differences betwee the two. Cam-it tells the computer the firing order Crank-" " " " " position of the no.1 piston and also the engine speed and other functions. Won't hurt to check it to include the EGR Good Luck!
https://images.2carpros.com/forum/automotive_pictures/12900_donate_4.gif
Aug 19, 2007 at 2:07 PM
TOMFITZY
  • 7 POSTS
It is an aztec engine, which means it has no egr valve. Tney removed the egr, and uses a cam sensoe solenoid to retard the timing. It uses oil pressure. I thought that may be it, I flushed the engine but it did not help.
Apr 19, 2009 at 10:46 AM
