1999 Ford Contour catalytic codes
1999 FORD CONTOUR
93,000 MILES • 6 CYL • 2WD • AUTOMATIC
SONNYT
car is running good, fuel economy is good, showing cat threshold codes for both cats. is there anything else that might likely cause these codes. The light has been on for 2 years and its time for inspection again. estimated cost for cats is 1400 to 2500 dollars. Thanks
Dec 15, 2007 at 12:03 AM
FLEXY5
  • CAR REPAIR CONTRIBUTOR
  • 512 POSTS
What specificly are the Codes? If they are cat threshhold there is no other option but to replace them.
Dec 15, 2007 at 9:53 AM
SONNYT
[quote:72d46ab306="flexy5"]What specificly are the Codes? If they are cat threshhold there is no other option but to replace them.[/quote:72d46ab306]
Hi, the codes are PO420 and PO430, thanks Homer
Dec 22, 2007 at 12:08 AM
