1998 Ford Contour won't start up all the time
SAMOT23
  • 1998 FORD CONTOUR
Engine Mechanical problem
1998 Ford Contour 4 cyl Front Wheel Drive 115000 miles
we go to any place, we shop, then when we want
to go back home the car won't start up.
lety it sit for 3 o 4 hrs. Then it will start up like
nothing happen.
Wednesday, October 21st, 2009 AT 9:09 PM
AVENUE723
  • 9 POSTS
IF ITS NOT CRANKING OVER-
Make sure/check:
1. Battery terminals are clean and tight.
2. Battery wires are not shorting out/broken etc.
3. Wires going to the starter are tight.
4. Car alarm(if equipped) is disabled.
5. Starter Relay is working
If its all good, could be a worn out starter, OR:
Transmission-
IF AUTOMATIC--Put transmission in neutral- then try to crank. It could be the sensor- if it doesnt sense that its in park/neutral- it wont crank.
IF MANUAL- Could be the clutch switch/sensor worn out.
If none of that works- It possibly could be the ignition switch/computer-
IF IT IS CRANKING OVER-
Could be
- fuel pump
- computer
If you do these steps- it should solve ur problem.
Wednesday, October 21st, 2009 AT 9:41 PM
