I have a 1998 contour with about 120,00 miles, just the other day i drove it to work and everything was fine. When I left to go home it would barely go when I put into drive, so I downshifted into 2nd gear and it proceeded to go then I shifted back to drive when the rpm's got high enuff, that worked for awhile now it won't even go in the lower gears. If I get the vehicle to actually to accelerate to higher gears it goes just fine. Does anyone have any ideas.
thanks
thanks
Apr 22, 2008 at 10:29 PM
