1998 Ford Contour
KNIGHT_GIRL2008
  • 1998 FORD CONTOUR
Transmission problem
1998 Ford Contour 4 cyl Two Wheel Drive Automatic
overdrive does not turn off and the transmission is very jerkey when shifting from 1st to 2nd also I can get to 70 mph on highway then after the transmission engages into neutral I have to come to a complete stop and put in park before it will reengage into drive what do you think the problem is?
Thursday, September 2nd, 2010 AT 10:23 PM
BMRFIXIT
  • 19,053 POSTS
1st step should be to check for tranny code
Once you have the codes post them for more help
If tranny with a lot of miles on it suspect internal tranny failure and replacement or rebuilt is needed
Friday, September 3rd, 2010 AT 6:23 PM
