1998 Ford Contour timing belt
142,000 MILES • 6 CYL • 2WD • AUTOMATIC
SWOODRASKA
The timing belt in my car was replaced about 5000 miles ago and now is giving me trouble again. I was told it needs to replaced, shouldn't they last for years, 100000 miles? Why is it doing this? Should I spend the money to fix it?
May 22, 2008 at 6:27 AM
MUSTANG87
  • 261 POSTS
are you sure its the timing belt?have u scanned the computer to check any codes?maybe your mechanik did a bad job.timing belts do last along time 60 to 80 to 130k even more sometimes .but normally is good to change it every 60kmiles . 5kmiles means they didnt do a good job.maybe you just have another problem and has similiar symptoms?
May 22, 2008 at 5:15 PM
SWOODRASKA
Yes, the timing belt is close to being shot. Any other ideas?
May 23, 2008 at 12:16 AM
MUSTANG87
  • 261 POSTS
yes ,invest .fix it and sell that car. ill be honest id never buy a contour its one of fords worst cars. no offense meant im just being honest.i see tons of those cars with bad head gaskets and transmission problems.even manual transmisions on those give to much problems.
May 23, 2008 at 9:48 AM
SWOODRASKA
Well, I spent 1400 on it to buy the car, to save on gas, it does do pretty good on mileage, 28 mpg. My plan was to run it until the wheels fell off. Sounds like that will come sooner than I expected. Thanks for your advice.
May 27, 2008 at 1:56 AM
MUSTANG87
  • 261 POSTS
your welcome
May 27, 2008 at 11:21 AM
