1998 Ford Contour Timing Belt
SILVERWING
  • 1998 FORD CONTOUR
  • 4 CYL
  • FWD
  • 145,000 MILES
Is 2.0L 1998 Ford Contour's engine an 'interference' or 'non-interference' engine?
Wednesday, March 10th, 2010 AT 10:26 AM
DOCFIXIT
  • 18,828 POSTS
Ford says non
Wednesday, March 10th, 2010 AT 12:35 PM
SILVERWING
Thanks for quick reply. My understanding is that this is an "either/or" question. My timing belt broke and I was told if non-interference type engine then I am lucky as I may only require new belt. If iinterference type engine then rods or piston may be bent and I am hooped. Any idea what I can expect to find once we look inside?
Wednesday, March 10th, 2010 AT 12:48 PM
DOCFIXIT
  • 18,828 POSTS
Yes this engine is a little ify some do bend valves others don't. If you where at 60+ then possible valve damage.
Won't know till belt is on and you spin it
Wednesday, March 10th, 2010 AT 1:08 PM
